Water pump
Luckily its run off the auxcillary belt so its pretty straight forward tbh. just make sure you put a new aux belt kit on too
Yea but when I drop the engine down I can't really get great access also what is the bolts holding it in.
it's a mess about actually. Lower cambelt cover off to give you better access (not necessary 100%, but easier) which means upper belt cover off. upper alternator bracket off, bumper off.
I don't remove the alternator bracket to remove the water pump. they are E8's iirc. its about an hour and a half to do, but thats with a ramp. Emma and I did hers on the floor and it was a PITA.
