Weird comp problem
DrR
  VW Golf GTD
Ok this is weird
Switch on comp, use as normal
Swith it off.
Then when i switch it on, have to turn on the power, press the button on the case, then switch it off at mains.
Then put the mains back on then press the button on the case again to make it boot
Any ideas?
Padso
  Merc
Unplug some of the USB devices from the computer one by one and you will find the problem.
DrR
  VW Golf GTD
Only have the mouse installed via USB, and it's never been a problem before.
Padso
  Merc
No other idea then as i had the same problem with USB devices on my computer with an ASUS board.
  172 Cup
Sounds like PC is going into a suspended state when you turn it off rather than shutting down properly.
DrR
  VW Golf GTD
IT switches off, all the fans etc turn off?
This is the same pc i posted up about the proccessor speeds.
DrR
  VW Golf GTD
Yeah not usb. It's only done it since for some random reason it lost all it's BIOS settings.
