RB 182
Hi Guys,
About two weeks ago I had my cam belt & aux belt changed. This was due to a leaking cam shaft seal. The old belts were about 15,000 miles old but had got a little oil etc on them so it was not a good idea to put them back on.
The work was carried out at a local garage, I was not comfortable driving the car far with oil leaking on the cam belt :/
The garage had carried out a cam belt change on cliosports before and had the correct renault tools.
Initially the work seemed pretty good, but now the engine is becoming noisey on idle it sounds like a diesel when cold there is also a a fairly high pitched whine. the engine sounds better as it warms up.
here is a video of the engine starting up from cold this morning.
http://vimeo.com/20094826
Is this something to worry about?
Could it be related to the cam belt work?
it sounded fine before I took it to the garage, but this could just be coincidence?
... im guessing you're going to say.... dephaser! but it seems better when warm.
