Hi guys,
This is a very strange one but I need the best possible solution a permanent fix and not replace my block.
Anyway my 182 cup is fitted with a pure Motorsport air con delete kit, however one of the fixing tags that is actually on the engine block used to support the alternator on one side has steered off completely.
What is the best way to fix this back onto the block as its cast iron which will be a permanent fix.
