found this listed under benefits on an ad on ebay (link at the bottom of the post)
Larger wheels will increase the look and performance of your car!
The performance increase is a result of mounting a wider, low profile tyre and a larger diameter wheel.
The tyre is wider and gives your car a wider stance.
Better lateral stability and increased steering response is achieved because the wheel is taller and the sidewalls of the tyre are shorter.
We can provide you with the correct tyre size to keep your car at the correct height, ensuring the gear ratio & speedometer reading on your car remain unchanged!
http://cgi.ebay.co.uk/15-100-Monza-...000557181QQcategoryZ28648QQrdZ1QQcmdZViewItem
