What bearing do you reckon this is
Car  Oyster Card
I need a bearing replacing in my Clio.
When I'm going straight or right it's fine but if I go above 20 and point the steering wheel anything past (Anti clockwise) the 10:00 position I get a low pitched rumble/vibrating feeling.
I did take it to a garage they fiddled with the front wheels but only found the front track rod end needed replacing as it was seized, that did make a little bit of diffrence but the noise is still there so I'm guessing it's a bearing.
How would I check and any idea of the price?
A new hub from Renault is probably £80 a second had one from a breakrs about £40 or less.
Dead easy to swop if no rust is present you can do it in under half an hour.
