what bolt is on the manifold to cat?
Car  R35 GTR
The one with the spring on it. Is it a standard one? Mine has threaded and rattling like a b**ch!
Thanks guys. Anyone managed to do replace it by getting down the back of the engine? Would it help if I removed some bits out the way?
Best off getting it jacked up and on stands, then lying on your back, with a few extensions on a ratchet.
Wouldn't use an 11mm spanner you'll round the bolt head if your not carefull
Thing is, I need someone inside engine bay holding other end of bolt. I'll probably cut it off and replace with something from work. Should go on easier than it comes off.
dave if you can, you could bring it to me and we can use the ramps at work plus the use of my tools. got quite a few of those bolts as well but not the renault ones.
