muzz said:the infinitys are 2 ohm so you need a 2ohm stable amp, if you are spending that amouth buy DLS R5As which are a straight swap for the exisitng ones, they are of a higher quality then the infinitys about the same if not slightly warmer than the rainbows and you can get them for £150.
Second hand i will ahve a look, are you prepared to do little work to make them fit?
bmh.01 said:I've got the cheaper Infinity Reference 5010CS components and there brilliant as far as i'm concerned, would imagine they'll be better still.
muz said:yes your profile 4 can run at 2 ohms per channel you get 4 x 70 Genesis RMS so it would be 4x100 in real world terms.
