What happens....
  Bumder With A Buffer
When you say turn off what do you mean??!
Stick down is off..up 1 is rain sensitive one
Next one up is on but slow
Last click is full speed ahead... Whoop Whoop!
Technically you can't turn off the Auto function, you can only have the options mentioned in the above post.
  Monaco 172
Ahhh, from reading a few threads on here I was under the impression that you could physically turn off the rain sensitive setting. Obviously not.
Thanks gents
  182 (Conversion)
You can turn them off.
IIRC all you need to do is have them in the off position when turning the ignition on (without starting the engine).
I read about 30 topics on it recently because I was trying to get mine to turn ON! :D
On mine atm the 1 Down position doesn't do anything - I'm not sure if when the auto is deactivated they're meant do nothing (as mine do now) or go into a manual intermittent mode.
do the cup's have auto wipers? I thought not...?
