What have you done to your car today ???
LeeRS
Cleaned before it goes into hibernation for a week.
Jme34
  clio 182
Cleaned up the engine bay a bit. Wire-brushed inlet mani/fuel rail guard, metal polished lettering. Wiped engine cover, added battery cover, sprayed fuse-box silver to match engine cover, polished up air-con pipes. Now needs a new coolant expansion tank and I'm on the fence as to whether to spray the battery cover and/or the air box silver too
Oh and I got a new gearstick insert too, it's the little things that make a difference [emoji6] haha
  • Like
Reactions: Gus
  Clio 182
Got new dunlop rubber all round and got turinis fitted at the same time.
Then gave the windscreen a quick spray and one of my wipers (finally) snapped so have ordered some bosch aeroblades.
Jme34
  clio 182
Did this
Unsure at the moment, plus it needs the original style light cluster, which doesn't clip into place properly in these housings
  clio 182
Well 2nd day of owner ship.
I wet flatted and cut back both headlights, spent 10 mins on each light, a massive difference.
Cleaned scorpion tips on exhaust.
Passenger side wing mirror, knackerd, bought a black one from scrappy, filled it, primed it, sprayed it and lacquered it.
Here's some photos.
The old wing mirror is available, all electrics etc work, but is in two bits, where gaffa tape is, in arctic blue.
  Clio 182
Just changed the injector really easy 15 mins.
Cleared the code before changed injector took it for a run and it runs 100 times better got home checked again with scanner no codes Fitted new top mounts so no more clunking
  BMW 320d SE
Found out my headlamp washers aren't working. Pump is fine, but testing it then made the jets leak, so off with the bumper to stop the dribbling. Still no headlight washer jets. :confused:
  Clio 172
Broken wire at ignition on 3 pin plug red wire, now car has went into immobilised, took positive off battery all day, connected back up now no lights on dash, radio is working but needs a code, mirrors and horn still work
  BMW 320d SE
I removed my non-working headlamp washers this morning, and replaced them with a couple of rubber grommets. Not too bad methinks, and a whole lot cheaper than carbon blanks!
Jme34
  clio 182
Dropped my car off today for a complete wheel refurb!
Going to get them done slightly darker, same colour as my brothers 172 wheels were done
  renault clio 172
Fitted yellow tinted fog lights, painted fuel cover, inlet manifold, rocker cover and cambelt cover
Renewed brake fluid and mopped headlights
  renault clio 172
no i aint 17 and i not on about fuel cap cover i on about the ally fuel rail cover under bonnet and 99 has nothing to do with my age
