What is the radio that comes with clio
Obviously, as i keep saying, getting my car in 3 weeks or so. Clio, dynamquie 1.4 with a digi pack.
so that means 4x40w radio in it.
Will this is the "tuner list " model? if that means anything to you.
I am trying to find a MP3 changers i can put in to the clio to replace the standard CD changer.
Rumour has it a sony one will work with a adapter if the radio has "tuner list" on the front, or something
Stuart
Tunner list just means it can have 6 programmed radio stations I think.
If you have a look in the Clio sales booklet they show a Sony MP3 player (same as the options one fitted to the A class < unless fact for the day). This should be the easiest to fit as Renault use it and might not need an adapter but check first.
You can stick almost any player in there the wiring is ISO so there no power problems and the speakers connectros can be redne if they dont work easy enought. Then to get the remote and head unit to work you can buy adaptors depending upon which head unit you want to use.
