what sort of camber??
  225 powered mk2
What Camber are you guys running... I had to buy a gauge the other day to sort mine, Atm im running just under 1 degrees positive on the front.
Is this too much?
Also when i try and and get it to just be dead straight at 0 the tyre rubs the coilover, i have Camber bolts, but am i looking at spacers if i want to put abit of negative camber in?
cheers all :)
  ph1-172
i think mine is set at 2degrees negative camber,
feels fine everyday, turn in is nice and sharp and doesn't seem to wear inside of the tyre away to quick either.
remember to do the tracking asap changing the camber will alter the toe and ruin your tyres.
  S4 Avant
You should be running negative camber on all wheels.
Standard figure for a 1*2 is 0.5 degrees negative i think.
  alien green rs133
5 or more negative
  SQ5
You need spacers if you want some neg. I'm running around -1.5 on one side and about -5 on the drivers side as the kerb didn't like my wheel!
