Now I would normally just do everything up by hand using judgement and check it after a few miles/days etc. But thought I may as well ask the question and get it right if possible.
So could someone please tell me the correct torque for the following suspension bolts/nuts:
1) Front strut bolts.
2) Rear strut bolts.
3) Wishbone to subframe bolts (one the front one there's two bolts, one after the washer and then another after the support bracket)
4) Hub pinch bolt.
5) Caliper bolts
6) Ball joint bolts
7) Outer ARB bracket bolt
8) Inner ARB bracket bolt.
9) Track rod end bolt
10) Inner track rod bolt
11) Front top mounts
12) Rear top mounts
Cheers :cheers:
4) Hub pinch bolt.
5) Caliper bolts
6) Ball joint bolts
12) Rear top mounts
Cheers :cheers:
