whats the offset on a mk2 ph2 1.2 16v??
as above question asks??
also can any of the following sizes fit my mk2 ph2 1.2 16v???
  1. Wheel Size 13x7" Offset - ET20 PCD - 4x100
  2. Wheel Size 13x8" Offset - ET20 PCD - 4x100
  3. Wheel Size 14x7" Offset - ET20 PCD - 4x100
  4. Wheel Size 15x5.5" Offset -ET25 PCD - 4x130
  5. Wheel Size 15x7" Offset -ET13 PCD - 4x100 or PCD - 4x130 Offset - ET16
i dont have a clue when it gets all technical. all i wanna know is will any of them fit :)
thanx
jay
Not looking good for those mate. I believe the ET on Mk2's is 45 and IIRC anything between 32-48 is considered OK to use. Couldn't say for definate off the top of my head.
Et is 37 with those they may fit but your arches will probably rub like a b*****d there is a bit of room to move the wheels out by reducing the ET you would really need to try a wheel on to see how bad it would be but i doubt it would work
4x100 is right and centre bore is 60.1 this might help you when looking
none of them will fit under the arches nicely, but i dont think they'll stick out.
my willys are a 15'' x 7'' width on a et 36, and fit perfectly.
in having a 7'' with an et of 20 you'll be 16mm further out, so it'll be right on the lip of the arch. if you went for low profile 13's i think you'll get away with it though. its a shame you havent got adjustable coilovers though, so you could stiffen it up to avoid it scrubbing.
ultimately you could fit 10'' wide wheels, but you'd just have to raise the suspension up until it didnt catch. so just wack them on :D
gonna PM me with what your fitting ;) as im being gay and going for old skool wheels lol
