Wheel offset of 140 & center bore of 55mm?
  01 Renaultsport Clio 172
Will this fit a clio 172 ph1? i thought offsets were an et number but im confused.
also what is the centre bore size for a clio?
Sam
Owen
ClioSport Admin
Dont think the offset will be 140mm mate (ET140)
Centre bore for my 182 is 60.1mm iirc
Owen
ClioSport Admin
ET means 'Einpresstiefe' which is 'insertion depth'
So, my wheels are ET45, or put simply 45mm offset
140 sounds more likely to be a PCD measurement, in which case they're no good clio's have a PCD of 4x100 not 4x140
no the pcd is 4x100, but for some reason the person has come back with 140 for the offset, im not sure what theyve measured.
Either way the bore is too small so they wont fit :-(
