if smaller wheels are better why do rally cars touring cars ect all use 17"+ alloys???
can fit 17s on a clio and lower it without having to modify anything without any problems if you run the correct offset wheels.
15 and 17 tyres prices are nearly the same in common sizes.
Generally smaller wheels weigh less, therefore less rotational mass and less torque required to accelerate them to any given speed. The mass is also closer to the central axis (hub). Cast your mind back to playing on roundabouts, when you lent out it slowed, when you moved into the centre its rotation accelerated and all with no external forces (mum / dad pushing) acting upon you.
i.e 17" have most of their mass further out than 15" wheels. 2" give or take depending on the rim construction.
Or something similar if I remember my A level Physics and Rotational Dynamics right :-|
Isn't every kilo lighter a wheel is equivalent to something like 4kgs when it's rotating?
Something like that anyway.
I would imagine that trying to pull a ton of car along takes more effort from the engine than trying to rotate a pair of wheels
Absolutely, but the engine will have to work harder to accelerate the car if you increase the rotational mass of the wheels and the brakes will have to work harder to stop the car if the rotational mass is increased.
http://www.ux1.eiu.edu/~cfadd/1150/09Rot/RotDyn.html
Another one of those irrelevant comments
So no i dont see a 15 inch rim helping a car to accelerate quicker than a 16 or 17 inch rim.
You're absolutely right, Isaac Newton was wrong and it's taken from 1687 and a genius like you to disprove it, we'll done!
Mr newtons theories do not take into account gearing and 150 bhp plus
