Wheel trouble
Car  FFFFFFFUUUUUUUUUUUU
I hadn't used my car since saturday when I washed it. I got into it today and set off to college but when I went to reverse it felt like it wouldn't go backwards, so I tried forwards same problem. Felt like there was something obstructing the rear passenger side wheel. So I gave it some more beans and it went. Then I there was some wierdness sound wise from the wheel, and it was as if the wheel was flat. So I jumped out and checked but it was fine. Then started it again and it was all good? Anyone know what this was?
Cheers.
Sounds like the handbrake has caused the rear brakes to stick the noises sound a bit like a clunk as they release under force
Yeah sounds about right. Was it anything to do with the wash? I did a jet up into the arches if that affects anything.
So its all good then? Or something that needs to be fixed? sorry I'm a complete amateur.
Bearing in mind they are drum brakes? I'm not sure what these shoes are though.
nah its fine, insted of putting the hand break on when leaving it for a long time ie over night, just leave it in gear. its fine, common in this weather
