I need some info on wheel and trye fitments for clio 16vs. At present im running 17" TSW evo Rs with 205/40/17 tyres on my valver which came with the car when i bought it a few months ago. Ive since had it lowered 35mm @the front and about 50mm @the back and the only rubbing i get is on full lock to the right which i can deal with. Im now in the process of buying some 17" Compomotive MOs in white (always wanted these wheels) and i was wondering if i should put 195/40/17 tyres on them rather than 205/40/17s, because according to the wheel & tyre guide on this and other websites it would give an overall diameter closer to the original spec:
Standard tyres: 185/50/15 = 584.5 mm dia.
17" Tyres: 205/40/17 = 595.8 mm
195/40/17 = 587.8 mm
which means the tyres im running at the moment are 11.3 mm larger than standard, and 195s would only be 3.3 mm.
Which leads me to the questions, is it possible to fit 195/40/17s? does it make any difference to accelleration or handling? and do any of you guys run 195/40/17s on your valver?
The main point i was curious about is the acceleration factor, i know this is all thoeretical but in order to keep the acceleration as good as possible should i be looking at the 195s? The reason i thought of this was that when i went to Santapod recently (with my old 205xs) i noticed people run their cars with the original wheels on up front which i assumed would be because bigger wheels give slower accelleration. So is there a difference, and if so would it be noticable?
I realise that this subject does get a bit complicated, but i thought someone may be able to clear this up for me.
Jay
