wheels buckled
Car  clio 172
are these salvageble bought my new ph1 and it has two buckled fronts there the standard oz wheels can these be saved thanks
Balancing out will still produce a wobble on the wheel in cornering and under braking if its bent up pretty bad. Best off repairing or replacing.
Mick
Should be easy enough to find some decent 2nd hand ones for sale.
Not always the cheapest option. I have a precision engineer next to me who does these for £15 a wheel and promises near perfect unless the rim is broken.
nt terrible would rather repair dont wanna buy another set could be same if you get were im coming from
Mick, you could be a life saver.
We have some really nasty ones, they do balance up ok, would be nice to have them a little straighter though,ATS keep telling me it's costing them a fortune in lead lol.
mine shake when up to speed no terribl tho fine vibration when i spon the wheel it has a flat spot on it ?
If you can get them to me Tony I'll put them thru his shop for you at cost. As long as the rim isn't split/cracked/fucked he can get it about bang on.
He's done a few repairs for me now and they're very good especially for the cash.
Mick
Sent from my BlackBerry 9900 using Tapatalk
If you can get them to me Tony I'll put them thru his shop for you at cost. As long as the rim isn't split/cracked/f**ked he can get it about bang on.
Mick
I might take you up on that, I'll try and sort out the worst ones.
I'll be in touch.
