oil temp switch is alongside the dipstick it is the same sender for oil temp and oil level and is a b**ch to get too unless u remove radiator. check the wiring could be a broken wire like mine was
thats the biggest pile of sh*t i have read all morning! the oil temp sender is located just to the left of the oil filter as you look at it it will be a green plug that plugs into a white one, it just undos with a socket or a spanner (quite a big one but cant remember how big) the sender you are referring to is the oil level sender which is next to the dipstick
What these guys said - its to the left of the oil filter on the front of the block.
Youll get to the oil filter/sensor from undernieth the front. Alternatively, take the bonnet off, slam panel off - youll then be able to pull the radiator forward enough to get access between it and the inlet manifold. If your radiator has a plastic shrowd, pull that out too while youre working.
