for a ph 1 172 because all i can find is for 172/182 and my understand is they dont fit ph1's?
You can cut a samco to fit, or just get a 90 degree elbow and run a breather filter on the idle valve.
you can make them fit matey i had a ph2 samco on mine and just cut it to fit
other option is a 90 bend from r1xhp or merlinmotorsport and an engine breather on the end of the idle air valve
just picked my coolant hoses up from sfs and they said they are still working on a induction hose but dont you have one mark?
yeah i have a 70mm 90deg bend without the breather pipe and just fitted a small oil breather the idle valve same job and a hel of a lot cheaper,
you just need to trim the elbow down and remove the air box mounting plate and strap,
simples
if you need a pic i'll take one close up so you can see how it fits
I'm working on this with mate and a group buy will be available in the next couple weeks
They guy I've been dealing with, Anthony has been in hospital recently for several weeks.
so where does the breather go then al it looks like its not connected in that pic? so just order a 70mm 90 degre bend from samco and?
Also mate are we still good for them trumpets and ducting when i get paid next week?
o ive been dealing with david, i was told today they are in the process of getting the tooling for one.
