Where do I put power cable in Mk2 Ph1
  Mk2 1.2 Campus
I'm fitting an amp into my clio but I'm not sure where to feed the power cable through from the engine bay into the car. Is there a hole which is any good for this or any suggestions where to make one?
Dave
  182, SQ7, Trafic
Just drill yourself a new hole next to the brake thingy and put your own grommet in it :)
  Black Gold Trophy
fitted my cable through that grommet, managed to pull the grommet out somehow, havent been able to get the f*cker back in since!
  Never above 25mpg
Fitted mine through the hole behind the glovebox, which in turn, feeds out through behind the battery... if this is the bonnet cable then I'm going to feel a r****d :p But yeah, loadsa cables there, hard to pull that rubber out.
  PH2 172
guna fit my wiring kit 2moz after work and get my sub working woohoo aint ahd a sub for almost a year missing th bass hope the vibe 10" active sounds good
