where is this coming from?
  2001 1.2 16v
anyone know where this oil is leaking from?
i got all connections/bolts off to remove plenham cover but it wouldn't budge so i just put it back together.!
wanted to check the rocker cover.
it appears to be coming from the head gasket but i'm not losing water.
any ideas?
cheers.
  LY 182
what is it? looked like oil in the pic
in which case yeah could be head gasket or cam cover gasket clean it all off and look from the highest point
  2001 1.2 16v
cant really see into the cam cover cos the plenham cover.
but i think its the head gasket then.
is it a difficult job? (considering i couldn't even get the fkn plenham cover off!!)
cheers
  LY 182
well relatively speaking its a simple headgasket to do,,
but yeah its an involved job requires cam timing setting tappets torquing head to correct specs etc etc
easy if you know how i guess
  2001 1.2 16v
could it be coming from the oil pressure switch and where is its location?
oil is pissing/spraying all over alternator and radiator now.!!!
any info wecomed.
thanx
  Dodgy one
I have no idea mate, looking at that though its pretty serious you must get through some oil, I'd have it in a garage to be checked out
  2001 1.2 16v
got car back from independent garage today.
put it in yesterday morning at 8:55am and got it back today at 3:30pm.
they changed rocker cover gasket (£90).
but the oil is still coming from the same place.!
its dripping down from the inlet manifold/plenum cover.
i've gunked and washed it and it doesn't seem to be coming from the cylinder head.
