Which brake fluid?
Steve
Car  LMC10, Puma E
Fast road track use any recommendations?
Had Castrol Super in the T.
Heard good things about SRF, but it's costly?
castrol super is fine, ATE superblue is rated too.
tbh if your boiling fluid you have issues lol.
I use car lube dot 4 in mine, never had a problem with it on track or road.
I was chatting to a pro rally driver the other day and he was saying that standard fluid for ABS brakes is as good as any, the lines are the important thing. He change them for braided and stick to the standard fluid for track. He's been a pro rally driver for 20 years and seemed to know his onions.
Rally nuts had the best price last time I checked for the ATE Super Blue Racing brake fluid...
£16.85 (although I am sure it was cheaper last year)
They where decent guys to deal with and a speedy delivery!
http://www.rallynuts.com
Yes, any DOT 5.1 is worth going for. Don't bother with DOT 4 as DOT 5.1 is higher spec and not too pricey.
5.1 is necessarily higher spec. It just has a higher boiling point. DONT buy cheap 5.1. I boiled it many times. You cant beat decent fluid
i thought DOT4 had a higher boiling point?
anyways, i use:
