which resistor should i
  monaco 172
just wondering does anyone know wat resistor i should use to knock my airbag and service light off. as i have just fitted a omp steering wheel.
Addz
  Trophy, TVR Tamora
I used 3.3ohm resistors on my seat airbag plugs if that helps!
  monaco 172
cheers man. i think there between 3.3 or 4.0 some post say diffrent sizes but never the same one. just dont want to f..k it up
  Bumder With A Buffer
Anything from about 2ohm-5 ohm should work.
Use 3.3 ohm to start with but just me mindfull that resistors have a tolerance of +/-10%...which could be enough to take it below the minumum resistance required. I used 3.9 ohm on mine.
  monaco 172
and did they work ok for you. is the a watt on them too.
3.9 ohm was fine. 0.25w should also be fine. Hardly any voltage running through the circuit.
Im guessing ul be going to maplin?? Get a 3.9 ohm 0.25w one. 1 watt would also be fine to use.
  monaco 172
yea theres one in dublin city. do i need two off them as there was two wires that came off the airbag. plus the horn one
