which screwdriver bit?
M.C..
I will be fitting a different steering wheel to my 182 but also fitting a indicator stalk with horn push, anybody know what the type of bit is to get the squib (I think that's what it is called ) off so I can get to the 2 screws that hold the indicator stalk on.
The steering wheel is a torx55 and then the scuib/indicator stalks are torx 15/20 from memory.
the wiper and indicator is a t15 iirc (managed to take the wiper stalk off as the screws were accessible with the squib still on) but the squib was a 5 sided star screw checked all my security bits and torx and nothing fitted so could not get to the indicator screws.
If a torx can undo it have you tried using a very small straight electrical screwdriver? It won't be done up tight so should work a treat.
