Whilst indicating fog lamp comes on??
Car  Trophy #382
Bit of a strange one but when I am indicating right and braking, the rear fog lamp flashes in tandem with the indicator? does anyone know what would cause this?
Sam
You need to take the rear lights off the car, clean the metal clusters with wd40, clean the metal connectors and bottom of bulbs slightly then reassemble.
Had the same problem myself recently and a clear of the connections solved it.
Also squirt a bit of wd40 inside the connector that connects to the lights.
