Whistle from drivers wing mirror
Car  Ford Focus ST2
On my 182 i got a wind whistle from the drivers side wing mirror at any thing for 25mph +.
I noticed this on my g/f's 1.2 Dynamique, is there anyway i can fix this?
Rob :D
Tape the gaping hole on the underside and the noise will dissapear until the tape falls off then repeat...
it is...but ther is a wee hole on the other side...
drive with your window down and stick your finger in the hole
Renault can stop it if you take it into your local dealers my trophy did and they sorted it .
f**king great hole if you look under the wing mirror, going to fill it with bluetack or something!
yep same with 1.4 extreme too, i think its the tiny gap between the bracket attached to the car and the actual mirror bracket. (basically the gap which allows it to fold up, hense why it stops once folded) cause when i put my finger in front of the gap (on top) then it stops
