Whistling noise??
  182 Cup
Basically when I was at the ring I noticed that under load, above about 60mph my car makes a whistling noise that kind of sounds like a beeping. It is intermittent and annoying. Ive noticed it gets worse and more constant at speed if I have a window open. It sounds like its coming from the vents in the center console, not sure though... Any ideas guys?? Thanks.
  CLIO172, BMW3, 3061.
whistling noise like thru the air vents??? mine does the same have been wondering where its coming from. can u block it up? only recently started doing this :-S
  Mini Clubman
there is a hole under the mirror where the temp sensor it and the wind wistles around that!
