Could be blowing from elsewhere along the exhaust. A small crack can make a lot of noise.
Had a new one of these when Fred welded the olive joint. Seemed to have disappeared for a while now the weather is worse really is noticeable again?Most common cause for this is the CAT to Manifold seal kit blowing due to wear or bolts no longer asserting adequate pressure or a worn fire ring. Look carefully at the joint for signs of black soot like stuff at the joint.
