whos done a rocker cover and head gasket on a 1.2 16v
Martin_172
anyone done a rocker cover and/or head gasket on a 1.2 16v?
my rocker cover gaskets gone and needing done and thought i might as well do the head gasket while im at it since its on 130k and leaking both oil and coolant somewhere!
how hard/easy are both, if the head gaskets pretty hard ill just leave it and see if the rocker cover gasket fixes the oil leak as its deffo leaking some from there.
what needs removed etc
cheers,
Martin
If the oil and coolent arn't mixing don't bother with the head gasget.
I wouldn't bother with the roacker cover unless you know its leaking oil.
I've got a guide on doing both which quotes how tigher to do the bolts PM me your emaill address if you want me to send you a copy.
oil and coolant arnt mixing so thats cool, rocker cover gasket is deffo leaking oil its all over the back of it but ill have another good look tomorrow, changed oil last month and its drank it all in 5k miles
ill pm you for that guide the now!
its dead easy take inlet plenium part off 10 at the front and female torx on the top. it happned to mine many moons ago the plastic plenium was cracked due to 75shot of nos
