Dirt buildup on headlamp lenses increases glare to other road users, even at levels too low to reduce seeing performance significantly for the driver. Therefore, headlamp lens cleaners are required by
ECE Regulation 48 on vehicles equipped with low-beam headlamps using light sources that have a reference luminous flux of 2,000 lumens or more. This includes all HID headlamps and some high-power halogen units. Some cars have lens cleaners fitted as standard or available as optional equipment even where the headlamp specifications and/or prevailing technical regulations do not require them. North America, for example, does not use ECE regulations, and
FMVSS 108 does not require lens cleaners on any headlamps, though they are permitted. Lens cleaning systems come in two main varieties: a small motor-driven wiper blade or brush conceptually similar to those used on the windshield of the car, or a fixed or pop-up high-pressure sprayer which cleans the lenses with a spray of windshield washer fluid.
