Will a Clio GT bumper fit my MK3 2006 Clio VVT S?
  MK3 Clio 1.6 VVT S
Hi
I quite like the Clio GT rear bumper with the cut out for a twin tail exhaust. Im just wondering if it would fit my 2006 Clio 1.6 VVT S?
Martin_172
yes it will fit and you will likely find the GT exhaust is identical to yours too so all you need is to order the GT tail pipes from renault and bolt on :)
  MK3 Clio 1.6 VVT S
I thought the 197 had a wider back end so the bumper wouldnt fit it? How much work is involved in getting it to fit if this is not the case?
  Clio III PH1
The 197 bumper is wider so the there's some bodywork to do on the rear wheels panels so it can match. This is not mandatory but it will look bad if you don't.
