Will a ph2 172 decat fit a ph1 172?
  BMW E46 330i Touring
I think it depends on what sort of cat the Ph1 has - there were two different types (single and twin Lambda I think...).
  Lots of Alfas
It wont fit!!! The ph1 cat is shorter than the ph2 cat. So the ph1 has a longer centre section. It will only fit if you use a ph2 centre section aswel.
  Lots of Alfas
Was it the twin cat with 2 sensors as my old twin cat with 1 sensor was the shorter type. They are about an inch and a half shorter. Im just wandering then if the one with 2 sensors is the same length as a ph2 cat (presumably they made it longer to fit the hole in for the 2nd sensor).
  PH1 172 Sport
The one with 2 sensors must be longer as when I fitted my sports cat from a PH2 it was a straight fit. Did they do the twin cat with 1 sensor then?
  Ph1
Yes, the double barrel type (twin cat) with the 2 lanbda sensor plugs.
Decat (Janspeed) was labeled for a ph2 / Cup but it fitted fine, no modding or anything.
They didnt do a shorter type twin barrel? Pretty sure it was either twin barrel or single box type, twin being on the later ones, single on the earlier versions.
  Lots of Alfas
I thought it was the other way round. All the w and x regs ive seen have the shorter twin type with 1 sensor. But some ys have the twin type with 2 sensors or the exact same box type one as the ph2. Janspeed also do a separate decat/sports cat for the ones with the shorter type.
In summary, the decat will fit as long as the ph1 has the later type twin sensor cats either box or twin type. You can tell by comparing the ends of the centre sections towards the cats end.
  172 Race Car
This old chesnut again.
Later phase 1's have similar stuff on them to the phas 2.
twin lambda sensors etc as they are post 2001 regs
