Will These Fit
  Track 172 & Golf R32
cant see why not i have a similar set of discs on my one, u just need to look at the diameter of the discs because they need to be the same as the standards ones for obvious reasons
Iridium
Honorary Member
  Former R27 & Mk1 V6 owner
If you have vented discs - then the K-Tec website suggests the 1.2 16v, 1.4 16v and 1.6 16v all have the same size discs.
http://www.k-tecracing.com/show_product.asp?id=243
I'd just buy them tbh mate - without meaning to sound like I'm taking the piss, your car has quite low power and weight, so spending that much on discs is a bit OTT - I understand why you'd want the drilled/grooved look though - but the black on those discs will also wear off VERY quickly in my experience. Just a thought :) You'll also need pads if you change the discs as well - as the old ones will be 'shaped' to your old discs. EBC Greenstuffs are a well priced option, and will be less dusty than OEM pads.
Dan
Iridium
Honorary Member
I assume been a 2003 16v he will definately have the vented calipers?
