Will these wheels fit?
Yeah, think I'll go with the 2nd ones, more or less same as original but slightly bigger lol.
They're just the slightly newer version of the oz f1's that are on standard ph1 172's.
yeah but the second one is a 7.5 rim, go care full you dont really want rubbing on corners phone demon tweeks up, the widest rim they reccomend would be a 7, ie 17x7 or 16x7, up to you though just offering advice,
it means how far the wheel sits off the hub, the higher the number the further it sits in the lower and the further it sits out, iirc 172 should be between 35/7mm & 40mm
Need to know as ordering today, will the 2nd wheels rub if suspension is standard and do people think they rub with a 20-30mm drop?
