all the tools required are available at halfords. piston ring compressor is 4quid, etc.
if ur getting bore wear, i.e. more than a thumb nails depth, get rehoned. u could go for a rebore, but 83mm wide pistons r custom spec stuff and cost an arm and a leg.
give it a rehone, professionally or with a 3 pronged glaze buster. i did it myself with 400grit emery cloth and wd40 - brushed up the bores no probs.
fit new rings at least. i couldnt get any rings from renault, they sed they dont sell em anymore. so i had to get a set from belgium through a local motorfactors. cost me 90quid inc vat and delivery. new bearings cost about 70quid all in.
rebuilding the cylinder block is a nights work once everythign is cleaned and prepared. i rebuilt my 2litre lump in my back garden on a black n decker work mate. keep evertyhing clean, keep it all lubed, and its easy peasy. way easier than building up a cylinder head. also why ur at it, fit a new oil pump as a matter of course and replace all the seals. once its all sorted ul have an engine thatl pull 16bar (230psi) on the compression tester - good by any1s standards.
jimbo
