How much is a williams crank shaft worth? in very good condition?
The 1.8 Block would require boreing out as the williams pistons are bigger, and i dont think running it on a valver crank would even drop the CR that much, if any!Quote: Originally posted by number1 on 19 December 2004
sorry to hijack this topic but if someone wanted to run a lower comp for a turbo could they use williams pistons in a 1.8 block with valver crank?? probably not but i just thought id ask
Dave
Runnig the valver crank in the 2.0 block would lower the CR considerably to somehting like 5.1 I think BenR mentioned it a while back.Quote: Originally posted by number1 on 19 December 2004
