Williams Gearbox and Uprated clutch
Im after a williams gearbox, either brand new or refurbished and not since used.
I know renault ones use the old shell but new gearbox internals!
How much am i looking at for one from renault inclusive of VAT?
Where else can i get one from?
Also i want a good strong uprated clutch and cable, after some trouble free mileage here!
but i want an uprated clutch, i wont be using standard power......big ass power so standard clutch needs to go in the bin! even though its a new valver one ive got on
You don't new an uprated one. Mine had an "uprated" one and the material cracked due to poor quality. The standard one is not only light enough for normal use but will stand upto about 210hp. If you do want an uprated one the 5GTT uses a 5mm bigger dimter setup one but unless you've got over 200hp you don't need it. The standard clucth is even fine for hard continious track day use.
