Valver kerb weight = 975 kg
Williams kerb weight = 990 kg
Where does the different come from?
Quote: Originally posted by Rhys on 15 August 2003
Bambam, the engine on the two is pretty much the same. If anything, the Williams F7R should be lighter than the valvers F7P as it has been bored out by 200cc!
I beleive it used the crankshaft from the Clio dieselQuote: Originally posted by RobFenn on 15 August 2003
Doesnt the Williams have bits from the Clio Diesel?
Wider front suspension in Williams maybe? Suspension parts are fairly heavy so theres a bit. Erm....not sure what else!
Stromba - are these actual weighbridge weights or magazine/manufacturer weights?
Im pretty sure these are manufacturers weights. Although i saw a quote of over 1000 kg yesterday for a Williams!!!!!!
Ive seen 990 so many time for the Williams i think that is the correct kerb weight. 975 kg seems to be the most often quoted as the kerb weight for the valver.
Thought the extra weight might come from my fat ass? Although i was surprised at only 15 kg extra![]()
