williams wont start!
Got my first problem with the williams. Starter motor is turning but the car wont fire up. Is there a weak spot with a williams where i should start looking ?
Any help greatly appreciated.
iv had similar problems on 2 occasions, and i bumped it and it started and sounded rough as fuk for a few mins then was fine. was told maybe tdc sensor so iv now replaced that!
ignition
fueling
check plugs are sparking first, take one out and rest it on the head and turn it over, u should see the plug sparking.
can u hear fuel pump priming when u switch ignition on?
[Edited by weight on 30 April 2004 at 5:49pm]
Ignition wires and or distributor cap can be shot. Replaced both on mine and starting woes were over.
Quote: Originally posted by weight on 30 April 2004
ignition
fueling
^^^^^^^^^ + failing that has she got compression??
