Williams3 Rear ABS Ring
Does anyone have any experience or knowledge of changing the rear discs on a williams3 with ABS. Ive been told that you can just take the ABS ring off the old disc and stick it on the new disc but dont want to find out you cnt when the cars in bits!
Euro Car Parts have the discs and say this is the case, as does BB Performance Tuning. Just wanted to triple check.
  20VT Clio & 9-5 HOT
as far as i know you can take it off and use it on the new hubs yeah! im sure someone will confirm though!
  172 cup,s2 rs turbo
its only a press fit so you should be able to change it. cant you get some discs with the ring already on them though as that would be easier.
  Trophy
Yeah, Trust me, get the discs from Reno. They come fitted with the bearing and reluctor ring.
Lot less hassle.
Mat.
Thnaks for the replys guys,
I ended up doing the disc change myself and found the ring came off easily with a puller. I can definatly see the benefits in buying discs with bearings and ABS rings already on but i did the lot without too many problems. For anyone thinking theyll use the old cir-clips out the old discs though, dont bother. Get a bearing kit with new ones cos theyre impossible to get out.
