Window washers?
markerboy2002
East Of England - Norfolk
Car  Liquid Yellow 182
My LY 182 has decide that when I want to wash the rear window (by twisting the end of the right hand stalk) that it wants to wash the front window instead. Any one else had this?
Hi, not sure if you meant the wiper or the spray. I had my washer motor out the other day because it was blocked, if its washing the front window but the back wiper is still working. Then when the front wipers spray the back, then it should be a case of swapping the tubes round on the washer motor (maybe someone did it at the garage???). there should be one popper that you press in the middle to pop out and the washer motor should be accessible without taking the wiper off. The process could be different though because mines a ph1. Really not sure though.
found the issue. It was a warning that the battery was about to die....which it did one day while at work. now thats been changed (due to a dead cell in the battery) It has been working fine. no more problem :approve:
