Windows Task Scheduler question.
mace¬
Car  Clio
Afternoon all,
If I do import task in Task Scheduler and import an xml file is it the same as entering the following at the command window:
schtasks.exe /Create /XML “[full path of the xml]" /tn "[taskname]"
Ta,
Thank you.
I just wondered if the command line would have given it any extra/different privileges and I couldn't find anything.
I assume everything needed or the task will be in the XML.
