I've got a RRAS server setup for VPN at a customers site. Just run of the mill PPTP one - usually dead easy to setup. However one of the remote workers can't access any files on the server.
I can VPN into the server no problem and access all the files.
He can get the VPN connected, can access the intranet webpage, can ping the server via IP and name. But when you run and do \\server it says path not found! same with \\192.168.0.5 (server ip) He has all the correct permission's (I've even VPNed in as the administrator on his machine and still can't access the files).
Firewall is configured correctly (controlled by GPO).
It's a domain laptop just taken home at the end of the day.
and yes his home network is on a different subnet.
Thoughts?
Thoughts?
