Malaman172
Renault Clio 172
Hi all i have an electrical issue with the above! Thing is it started with washer not working so i tried the remove washer bottle guide to check motors on pumps that was ok! However went to a local garage and mentioned my issue and they checked the electrical connections to the washer pumps (2). However whilst doing this the guy decided to stick two wires coming from the connection (electrical) to the battery which resulted in some smoke and possibly a buggered RELAY! Thing is after that episode my rear wiper rear reverse lights front auto wipe and climate control now all don't work however i started car today pressed on brake and heaters came on so don't think resistors are goosed! So i'm assuming these components serve on the same circuit so hopefully a relay change may resolve this! Also the smoke episode trigged serv light to come on hence the system knows something is wrong! All i want to know is am i on the right lines and is it worth getting an auto electrician on the job!
