windscreen washer advice
  Clio 172 Phase II
Washers work fine on the headlights. Washers have stopped working on the windscreen and the rear window (at the same time). I can hear the pump trying when I spray the screen to clean it but no water is released to either front or back screens......
Does this mean it’s just the fuse that’s gone wrong here or could it be something else?
Sorry to bring this issue up again guys, I just need some clarity on what the best thing to do is before I fiddle with the pump or anything.
Jon
  Clio 172mk2
try pin in the squirter holes , make sure no polish is blocking , if u can hear the motor spinning then it wont be a fuse.
after that pull piping off and see if it pumps out, might be the jets blocked
  Clio 172 Phase II
yeh i thought that about the fuse. ill give the above a try
thank you
