massiveCoRbyn
Several
I'm having some issues with the wipers in my 197. Basically, they don't work properly, and someone has fitted a little rocker switch to bypass the existing wiring. I've removed the motor/mechanism and cleaned it up and, with the Heath Robinson switch, they work, but they don't work on the stalk. The stalk isn't the issue (as I have tried another one), so I think it's the wiring, as it's pretty knackered at the wiper motor end (partially stripped wires for one thing).
The earth is still ok (as the "new" switch is tapped into it), and there appears to be a permanent live to another pin. But the other two wires appear to be dead, regardless of switch position, which I assume is the problem.
If anyone has a wiring diagram, or any experience of wiper faults, I'd appreciate it!
