Wiring door speakers!
Car  Hondata'd EP3 Type R
Hi, As I do not want to modify the car in anyway, I've decided to connect the speaker wire from my amp to the stock wiring as it enters the car from the door loom. I know this isnt the best route, But with some no loss connectors, And the fact the stock wiring will only be over a small length, I'm sure it will be ample.
However, On my car, The wires change colour as soon as they get into the car!
The car is an 04 Clio Dynamique. Any idea what colours to cut, I cut the positive for the Electric windows on accident earlier
So had to reconnect that
Any ideas? What i thought would be a 10 minute job, Took ages and didnt get the job done in the end
thanks
what colour where the ones in the footwell dude?
cant really remember,
wat i did was find the wires going from the speaker to the connector block and as they were diff colours i just looked at which holes in the block they went into it and found the wires at the other side in the corresponding ones if that makes sense;)
If it makes any sense then I did mine like so:
http://www.cliosport.net/forum/showpost.php?p=2113021&postcount=3
Saves cutting or modifiying any of the original wiring so it can be returned to standard easily, now obviously not the best still using the stock door runs but as long as your not using mega wattages I can't see a problem.
And the colours shouldn't change according to the wiring guide (although I know they do!).
Yeah was so pissed off when i realised they changed.
The cross over is an idea, But I am running 125wrms+ so Would like to use thicker cable, I'm going to do it the same way as Brun, But no idea how to get to those torques screws, Going to pop to B&Q in a minute to have alook at tools :)
I';ve got one in, Been the silly t**t I am managed to take out 2 wires, So had to solder them up, Got to finish off tomorrow.
I hate car audio.
