Dan Page said:
so whats the best way for me to do it then? please help
Dan, disconnect and unscrew the grommet that goes through to the door (2 torx screws). Then pull the block out towards the inside of the car.
You will see a block with 3 rows of wires. The wires in the centre row right at the bottom are the speaker wires.
dotted in red are the speaker wires. You wont have the 2 holes as shown above, its been modded, But the wires are in the centre at the curved end, shown in red here.
Cut these wires in a place that lets you access them... then crimp a Bullet connector onto them. Then run the speaker cable from your amp and connect it directly to the bullet connectors (using opposite connectors).
This will mean that if you take the amp out at a later date, you can just re-connect the standard cable that you cut, again using bullet connectors.
Hope this helps.
